Re: China Girl Cent Clutch/Pull Start Pros&Cons
I have the CC, but not the pull start. Absolutely love it, best upgrade I have ever done to the bike. It was a pain to get it to fit right, because I had to grind a notch for the small woodruff key in the CC, and had to grind the inside of it to make it fit properly, and I had to get wide cranks, but after all of that. It was very worth it. Idle is great with the NT, but after installing my RT carb its even better. I just pull the clutch to start, and let go of it and forget about it. With the RT carb it idles super low, when I lift the rear tire up, it doesn't spin at all. So I just hop on give it gas and were off.
Theres only a small power loss when you first start going, but after your up to like 6 mph its like a regular bike.
These little things need to come with a CC pre installed. What the point of a manual clutch system when its one gear, and you can't even use the clutch to go from a stop because the clutch pucks are so weak.
Then only thing I have to add is just make sure you have the tools to install it, and your clutch pucks are good and it's not slipping.
Also, I weigh 170, and use a 32T sprocket, and it still pulls great from a dead stop with no pedaling.
