Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 2 Stroke Bicycle Engines & Kits
2 Stroke Bicycle Engines & Kits 2 stroke engine kits need careful installation and setup, find out how from our professionals here!
Old 02-15-2017, 09:07 PM
Neptunati Neptunati is offline
Default 55mph Dio Reed Gt80 Rse Zeda PK80 80cc MOTOR ENGINE KIT GAS MOTORIZED BICYCLE
So apparently this is a sleeve motor. it's got a converted dio 6? petal reed block. Balanced crank, and lots of porting. Pk80 base motor. This is the gen 2 gt80 motor. Looks and sounds amazing! Who's buying one? Retail 499.99. I really want one but for that price I can get a nice actual dirt bike on Craig's list. Thoughts...?
https://youtu.be/uLERkCCt24U
Old 02-15-2017, 11:58 PM
quik225 quik225 is offline
Default Re: 55mph Dio Reed Gt80 Rse Zeda PK80 80cc MOTOR ENGINE KIT GAS MOTORIZED BICYCLE
So these are made in the USA?
Why do I have doubts?
Maybe rebuilt in the USA.
Old 02-16-2017, 10:11 AM
Venice Motor Bikes's Avatar
'Built' in USA & 'Made' in USA are two totally different things. (built means that it was only assembled here). :/
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 02-18-2017, 08:26 PM
https://youtu.be/1-lneS-80AA
So unless that's a special motor in the video all these motors are sleeved? Which is different than all the other China dolls? I highly doubt it. I really doubt that motor is sleeved in the video. Not just the regular chrome-lined cylinder. But I'm really liking the intake manifold setup on this motor. And yes all these China Motors are made in China but can be assembled by anybody here in the United States. The other thing it states that on his Zeda Motorsports website that you can get it with a jake head period for like 200 bucks. But then they offer the same exact thing with the same exact looking head for like 40 bucks cheaper something. Kind of confusing. And I really thought there be some more comments about that new intake reed block set up on here.
Old 02-22-2017, 09:12 PM
Solmangrundy's Avatar
Solmangrundy Solmangrundy is offline
Zeda 80 Engine:
Complete - Assembled - Lower End
-Big Engine Mount Studs (8mm x 1.25)
-Wide Front Engine Mount "Big Tube" (40mm Spacing)
ZL-E80 Rod Crank
-Long Stroke (40mm)
-Long Rod (Type B Piston)
-Wide Crank (Pre-Stuffed Case)
-Thick Crank Bearing Casting's (Pre-Stuffed Case)
-Wide Intake Port (40mm)
-Round Exhaust Port
Top End Kit
-Head
-Cylinder
-Piston
-Piston Rings
-Wrist Pin
-Wrist Pin Bearing
-Wrist Pin Clips
-Gasket Kit
-Spark Plug
-Stock Intake Manifold
Great starting point for high-output engine build!
Copied from Apollo Moto Racing
https://m.facebook.com/commerce/prod...245&rt=6&hsi=0
MotorBicycling.com
