These two rotors are over 20 deg apart in timing!
The more advanced rotor is coming out of the phantom and going on the goat, the Phantom is going to get the retarded magnet, as it is being detuned, but has a crank that's smooth to rev, so not a race bike , but will still rev out.
The Goat now has low gearing, big heat dispersal, only .2mm base gasket, high compression, reeds, heaps of advance and with a long freeflowing pipe, I want wheel stands!
I see the difference in these Mag Rotors as one of the biggest reasons one bike will behave totally different to another 'standard motor'.
Still if you have a choice of different Rotors, they can be used to give your motor a nudge in the direction you want.
Hopefully I have repaired my old timing light, and will soon be able to have these motors running and get some real timing numbers from these motors.
