Welding onto the Sturmey archer drum brake lever (to forks)
Danschutz
392
Wyoming
Not sure what kind of metal it is made of and Im buying a drum brake from a forum member however the brake lever has been modified to fit his fork and will need that piece extended back to original form. You cant buy that piece separate as they require you to purchase the whole side which is pricey so I figured maybe a weld would work.
Thanks for any help fellows!
Dan.
chainmaker
2,634
69
48
Ma USA
I wouldn't suggest welding the arm, best bet would be to weld a stud to the fork for the arm to fit onto.
2door
Moderator
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
Is it steel or aluminum? Try sticking a magnet to it. If the magnet doesn't stick then it is a good bet that it is either aluminum or a stainless steel alloy.
If it's aluminum it can be welded but whoever does it MUST know what he's doing. If stainless or mild steel the task becomes easier but still needs to be done by a competent welder. Brakes are not something to be taken lightly. Sounds like a job for a professional welder. Ask Bairdco what happens when a front drum brake arm comes loose. http://motorbicycling.com/showthread.php?t=45937
