About 24 mph and a 32 tooth gave me 29 no other modsHow fast does your occ chopper go wit a 44 tooth sprocket? thanks
well, if you want it to work right either b prepared to fork over the dough, or work on that laziness while jammin to the Stones singin' "you cant always get what you want...."Sorry i want to achieve at least 30. The motor mount i made i cant really adjust and I'm so tired of custom making things i just want a simple fix.
when i did my occ i got good results with the 10t from motor to a 10t on j shaft and a 12t to a 44tOkay this is what i got. I'm putting a jack shaft on it, i already put a ten tooth sprocket on the jack shaft from the shaft to the motor. How man teeth should be on the sprocket next to it. I'm not running the the chain to the free wheel side. I'm just doing it to move the chain over how ever far it has to go to get past the wheel. And i figured i could gear it up from the shaft. Well that's what i got could someone help. Thanks
