I have a feeling this will work. I have a trick 1973 Yamaha GT1/GT80 that I just scored a Webco head for and I think the carb will work perfect on a 2 stroke 66cc bicycle engine. Yamaha made the GT80 for close/over 10 years so I know you can get jets from Yamaha. Take a look at the pic's. The intake flange is just a little bigger but I'm sure you can shim it up. The over all size of the carb is not much bigger but as you can see in the pic's the slide is much larger. You have a air/fuel screw, slow and high speed jets! What more can you ask for? I'm going to try this out here soon on my bike and play around with jets. I will let you know how it works out. If anyone else has used a Yamaha GT80 carb, please let me know what size jets you are using if you are @ sea-level. I'm sure you can pick these carbs up on E-bay cheap. 5000
