HI Guys,
The dilemma of running small sprockets on a Manic Mechanic Hub Adapter has been solved!
Here is a cut and paste description that was uploaded to our You Tube Channel today....We will be updating our website shortly.....Other than those 2 places you are hearing about it here first! ;-)
To help those interested in seeing the video here is the link (if it does not work you can find the video under our you tube channel for :kingssalesandservice)
http://youtu.be/VDGXlow2aB4
Kings Sales and Service is proud to introduce "Sombrero" - A new version of its now famous Top Hat Sprocket Adapter which is designed to allow Manic Mechanic hub adapters to run sprockets smaller than about 35T.
NOTE: Because the manic Mechanic hub adapters run 3/8" bolts on a large 3 5/8" bolt circle, the choice of running smaller diameter sprockets was severely limited....The Sombrero Top Hat Sprocket Adapter (named so because the width of the "brim" is somewhat larger than the standard "Top Hat" making the hat look similar to a Mexican Sombrero) allows the use of sprockets much smaller than would otherwise be possible when using the manic Mechanic Hub Adapters alone.
The ability to use smaller sprockets on the Manic Mechanic hub adapters greatly benefits users looking for higher speeds, more relaxed cruising RPMs and riders using bikes equipped with smaller wheels which need the smaller sprockets to make up for the smaller diameter wheels.
Thanks to Stewpedassle for having us look into building this new product....Looking forward to any and all user feedback to help refine this new product / variation on our tried and true Top Hat Sprocket Adapters.
NOTE: pic 1 shows top view of Sombrero VS Top Hat , Pic 2 is bottom view , pic 3 Shows how sprocket mounting bolt mounts attach (center bore made intentionally large to clear most any hub....small amount of "break through" will not affect structural integrity.
Andrew
Andrew
