Last weekend, I was riding my bike like always and all of a sudden, I heard a weird pop sound and felt a quick jerk. I thought maybe my clutch internal got messed up. After stopping and shutting down the engine, I started to pedal around to see what is wrong. The clutch still works fine and engages and disengages like normal, but I do notice that when the clutch is in, I can turn the engine easier than before. It is as if I unscrewed the spark plug slightly, allowing easier compression. But the spark plug is on tight and all cylinder seals are still intact. Yet the engine turn rather easily with the clutch in. I tried to start the engine again and while it starts up, it lacks power and as soon as I idle for a couple of seconds, the engine dies. If I kept the RPMs high enough, the engine will run, but at a very weakened state. Nothing is leaking.
I rode it back home and checked the clutch plate and everything appeared normal. I took off the cylinder head and examined the inside and I noticed my piston has a small part of the top edge nicked in a couple places, like a piece of it was taken out. I also noticed a large vertical shallow groove gouged into the cylinder wall. The piston itself moves freely and doesn't bind or get caught on anything, but I am guessing my engine is dead. Would shallow groove in the cylinder wall cause easier compression and present with problems such as easier turning of motor when off and weakened power and inability to idle? Should I buy a replacement piston and cylinder or is it better to buy a whole new engine?
