I am installing my first Grubee SkyHawk 2010 66cc engine kit and have found the instructions for installing the sprocket to be a bit vague. I want to get it right so I am hoping someone here will help me out a bit.
I have the standard sprocket, two rubber discs, a two piece round metal bracket, a three piece round metal bracket and nuts and bolts.
The sprocket fits my wheel perfectly, so I don't have problems in that area, but I am confused about the order of assembly of the parts.
First off, which side of the sprocket faces in toward the spokes? I am assuming the sprocket mounts so the offset moves the chain away from the spokes??
Next, I know one rubber disc goes on the inside of the spokes, but what about the other? Do I need a rubber disk on BOTH sides of the spokes? (one behind the sprocket and one on the other side of the spokes?)
Finally, I know one set of metal plates goes inside the hub, but what about the other?
The instructions are confusing, the illustration seems to show BOTH rubber disks and both sets of metal plates stacked up inside the spokes?
I know its not rocket science, but I am kinda lost as to what they are telling me to do here... Some instruction and/or pictures of a properly assembled sprocket would be helpul to me...
Thanks in advance for your input...
