I'm for sure not the first person to do this. I needed a home for the new Grubee I just got and this bike was sitting waiting on an E conversion kit I have. So it got tapped to run the Grubee. May be an E bike later.
Fabbed a set of bolt on mounts. Was going to weld to the frame but figured
the tubing was thin and would eventually fail.
Its roughed out now waiting on the rear sprocket to set the chain line before welding the mounts together. I will have to ditch the rear disc which I hate doing but its the only way to make this work that I can see. The front will stop it fine and the tire has enough bite to handle front only braking. This wont be a terribly fast bike anyway.
Carb just clears the frame. Pedal clears the engine just fine. I imagine it will take an idler on the wrong side of the chain to clear the frame.
So far so good.
So far so good.
