I had a Ryobi 31cc weedbeater motor on my occ chopper. friction drive had driveshaft to support clutch(aint riding anything that wont sit and idle) had it geared as best as possible would climb any hill with very little pedaling. top end left a little to be disered. ran great except on down hill runs with engine redlined, when you let off gas was throwing driveshaft out of clutch. several designs and clutch housing was about cashed. happen across poulan 335 head unit at yard sale $3.00. loved the bearing on clutch and strong housing. messed with it and it went right in place. then the surprise this thing is a monster! 35cc will absolutely dust the Ryobi. took longer tuning it (tuning this thing is not for weak of heart!) then mounting it, but at cruising half throttle still faster and stronger then 31cc Ryobi. WOT is chilling, after first ride put a kill switch on it! Bring on any single speed bike from standing start to top end , I will show you a trick!! my tail light! I have a cooling issue, but have moved gas tank (it was directly under air intake) and replaced it with scoop to catch air. made sheet metal baffle for muffler and cut some slots in housing to utilize air flow(think in air turbulence at speed hot air off muffler was circulating in housing). think it will work, find out soon!
