ok i have a conflict with my dax build and i can decide what intake to use.
i have the aluminum shorty and the steel long z offset intake at my desposal
ok here are the facts...
the long z offset intake is about 6in long and has a 16.25 mm inner diamiter and a slightly better port match due to its larger opening
the shortty aluminum intake that comes stock on the dax and others like the pk80 is about 3 in long and has a 13mm inner diamiter and a real small opening that needed srs dremal work to get it to match the port.
i conclude that the longer intake with its 3.25mm larger boar that is size matched to the cns carb will flow easyer than the shorty and due to its length may help add bottom end to the motor due to the volumizing effect beacause of the amount of fuel stored in the manifold between strokes.
long z intake = better flow and bottom end
that does not mean that the shorty is bad or less effective in any way, here is why, first its shorter witch would lead to faster delivery of fuel during higher rpms, second because it has a smaller boar the fuel may be harder to pull though (slightly) but it will go though faster and with more preasure, IE the straw effect ... blow through a huge straw and the wind that comes out has no force to it, to blow the same amount of air through a real thin straw it may require more force but the air coming out the end will exit at a high rate of speed and with mutch more force.
shorty intake smaller diamiter = quicker fuel delivery and faster more forcefull fuel delivery, good top end but may rob some low end due to the extra force required to suck the fuel through the 3.25mm smaller boar.
then again this is all speculation as i have not individualy tested bolth on a well broke in motor under the same circumstances.
what do you all think ? witch would you use ? the z intake has a slightly larger boar than the boar of my carb. carb is 16mm intake is 16.25 there would be no restriction aside from the turbulance caused by the bends in the manifold, if i were to use the shorty, my carbs venturi would be restricted by 3mm but would flow fuel a much faster rate into the motor because its half the length and has only a minor bend that has been smoothed out and it is smaller in diamiter.
what would you use ?
the 13mm boar shorty
or the 16.25mm boar long offset z
the last pic you can physicaly see the differance in boar size.
