Just finished installing a sbp shifter kit. I go to start it, put it in first gear, pedal, let out the clutch and the engine won't turn over. only by stomping on the pedals can I get it to turn over, and I definitely cannot keep pedaling under the compression of the engine. I actually have stated it using starter fluid spray, and it's much easier when the engines warm. I don't think it should be this difficult, do I need a new cassette that allows for more torque?
Also I cannot go from a stop in first and turning over the engine is easy without the spark plug (like it should be).
