First a little background story.
I have a Giant Stiletto and I think I finally picked an affordable and more reliable than a ChinaHT engine for it. The Dax GT50 2stroke or the same engine I found cheaper that already has the Stage II or III upgrade kit. The Stiletto has a jackshaft in the form of a standard 3 piece crank bottom bracket were it links 2 chains. This is a large chopper with a 24x3 rear tire.
Now on to the actual question.
I have a few options on how to set this motor up. Both options would go to a standard fixed gear bike sprocket that can range from 17-22 teeth, then to the bikes gears, a Shimano 7 speed hub with Megarange as they call it. Actually I could use two different size sprockets, an example would be 18 on engine side then a 20 on the pedal side that goes to the bikes gears. Currently I have a 20 on the pedal side. I would rather not change that since I can't get it back apart and would cost me about $30 to replace the parts.
Option 1: Use a standard pocket bike gearbox that is just the clutch bell with a 6 tooth sprocket and a housing that bolts to the engine. There may be other size sprockets but I haven't looked that hard yet. This option is cheaper and the one I would prefer to use for a few other reasons.
Option 2: Dax 3:1 gearbox with the option of 11, 14, or 20 tooth sproket.
I am clueless when it comes to gear ratios or I wouldn't bother asking. Actually if I hadn't seen Staton-Inc using a gearbox on the same bike I would have just tried Option 1, since there have been a few ChinaHT builds with no gearbox. After some digging around, the Staton-Inc gearbox that they sell with there Stiletto kit is a 18.75:1 reduction.
Basically, can I run this type of engine without a gearbox or should I use a gearbox and what kind of reduction should the gearbox have if I should run this setup with one?
