This was my second motorized bicycle kit. It was made by Staton. It is a really substantial chunk of metal. This U channel should last forever. I liked it but it wore out my tires from the inside too fast. The threads would pop out and then pop the inner tube. I kept using it until the little metal roller was worn down too much.
The bearings on this are totally worn and need to be replaced. I have bearings somewhere in my storage unit but I can't find them right now. So those new replacement bearings from Staton aren't included in this. When I eventually find them I will list them for sale here.
This is a well made kit with very few things to go wrong. Mine is just in need of replacement parts. I think the roller size on this one is one inch. It worked well with the 32 cc Tanaka motor I had from my Golden Eagle kit. The roller is worn and should be replaced too.
What I have for sale is the basic friction kit with two mounting supports for the rear and the one U shaped mount for the front. The quick release tensioner wore out and isn't included. About the time this kit was wearing down I ordered a different one. That is when I stopped using this one. Look at the attached photos to see it all.
All I want for this one is $30 plus shipping. We'll need to figure out shipping. It must be done using the USPS because I can walk to that one. It is just a mile away from my home.
To be clear; you will need new bearings and a way to mount them. I didn't have the equipment to do it and that is why I didn't immediately install my replacement bearings. Thus I've misplaced them. You will need to replace the roller because the one installed is a bit smooth. If you like to add glue and sand to your rollers then you might be able to refurbish this one. You'll still need the bearings. and you'll need a new quick release tensioner to hold it in place.
Let me know soon that you want it and we'll figure out the shipping cost.
Thank you.
Michael
Smallwheels
Thank you.
Michael
Smallwheels
