Been looking for an engine to replace my Honda gx31 that I ripped the engine casing/housing in half. Found a couple of engines but not sure if they would work or if they are able to be mounted horizonal without any engine damage. If you could let me know I would appreciate it.
Looked at the Harbor Freight Central Machinery 1.5 hp Auger engine = $159.00, and the Earthquake 43cc 2 cycle Auger engine.
both of these engines are mounted vertical, Are they able to be mounted horizontal without any damage to engine? I don't plan on using the stock gas tank.
Any reviews on these engines with a bicycle build?
I know the RPM at the bit is 150 rpm but that is with a 40 to 1 gear reduction.
The guy at harbor freight didn't know and it was not listed the max rpm the engine turned.
I think both of these have the 76mm centrifugal clutch. Not sure though, If anyone knows, I would appreciate it. I took some picts of the HF Central Machinery Auger engine when I was at the store. Check attachments.
Thanks,
I figured, If it would work I would just buy the whole damn auger. take off the engine and sell the rest on ebay.
Thanks,
Thanks,
Thanks,
