Hi Folks - This is is my first build and I'm excited to almost be done with it! Thanks to to this forum I've been able to solve most of my issues.
I have two problems that are probably related, maybe you can help!
I can get the engine started no problem and cruise my neighborhood at a low speed.
1. But I get no response from the engine when I turn the throttle.
2. If I pull the clutch in, the gear disengages well but the engine revs up full throttle immediately. Similarly, with the the clutch out the throttle is "stuck on" if I don't stay on the breaks to control my speed.
However, when I take the carb top off and expose the throttle mechanism (like pic), I get a totally normal action on it, it pulls up and the spring bounces back.
So I can't find anything to fix in the throttle mechanism.
I'm not entirely sure how to set the idle on the carb so I can't confirm if I have it set nice and low like I would like.
Thanks for the help y'all!
