Coaster brake kickbacks under hard braking.....
borntofli
306
tx
Gentle pressure no problems, but hard braking it kicks back and there is no stopping the peddles...... What do I have adjusted wrong???
Huffy cranbrook....
bigbutterbean
2,417
Lebanon, PA
either your brake arm is not secured to the frame, or you toasted your hub. They dont often put too much grease in them at the factory, so greasing the entire inside of the hub before operating the motor is a good idea.
Venice Motor Bikes
Mar 20, 2008
7,272
1,810
Los Angeles, CA.
I think the brake arm is stripped!
Take it off the hub, & I'll bet the center of the arm is destroyed. :(
When you bolt the arm back on the hub after intalling a engine sprocket, you have to torque the sh** out of the bolt that holds the arm on! (& you also have to KEEP the bearing dust cover on)! ;)
biknut
6,632
411
83
Dallas
Mine used to sometimes do that with nothing wrong with it. The problem is you've probably got a cheapo chinese replica of a Shimano 110 hub.
What you need to do is toss it in the trash and get the real thing. There's no comparison in the quality.
bairdco
a guy who makes cool bikes
Aug 18, 2009
6,537
264
all of the above...
plus, when it gets worse, it can start pedaling forward suddenly at the speed of the wheel's rotation. like a fixed gear. and that's not something you want to happen at 30+mph.
