I have read all the threads that I could find regarding the HT engine generator and the possibilities of using the White Wire to power a self contained lighting system. There still seems to be a lot of confusion regarding output voltage and available power. I have done a lot of experimenting and would like to share my findings with the community. The configuration I am using is a fullwave bridge rectifier connected between the WW tap and the grounded end of the coil. I unsoldered the grounded end from the laminate and made a binding post using a 1/2 watt resistor epoxied into the hole in the core adjacent to soldered attach point. I clipped the lead off one side and left 1/8" on the exposed end of the resistor to wrap and solder the fine copper wire of the coil. The '-' pin of the bridge is grounded to the engine case and "+" pin is the output. A schematic of the test circuit is shown in the attached jpg. I used several resistors to load the output and measured the load voltage over 3 engine speeds. The lowest was a putt-putt idle, then a faster idle, and finally rev'd to the equivalent of about 15 mph. The chart on the left shows load voltage on the x axis and load current in amps on the y axis for the 3 engine speeds. The chart on the right is the power out curves for the 3 speeds. The x axis is load resistance and the y axis is the load power in watts. What may be surprising to some is the usable voltage is in the 20V range and around 4 watts can be extracted at reduced voltage. The tradeoff is you have to reduce the load at idle or the CDI will be starved and the engine will die. This is my first post and I am not sure if the the jpg file is attached.
