You need to mix your fuel in a separate container, not the bike fuel tank.
The primary gears (right side of engine) only require a small dab of grease every so often. Don't over do it because the clutch is a dry friction surface and excessive lubrication will compromise the clutch friction pads. No other lubrication is necessary except for the clutch actuator cam, pin and ball that make up the moving parts of the clutch actuator.
