hi, I'm new to this forum, my son's 50cc Morini engine has seized, managed to pull it apart but can't remove the clutch basket - I don't have a puller - can it be done without one? If so, how? cheers
First it would be nice to see a picture of the clutch there are a few models out there. If it is one of these URL="http://www.morinifrancousa.com/engine2.htm"]Morini Franco USA[/URL Then I can help. Without a puller you are going to have to wiggle it off. That is how mine always came off. I have never used a puller. I have had mine apart a few times trying to tame a shift kit.There are two different sizes
Rough about here explains what happened to me.Theres
Good timing on this thread...
From the photos, I have the 'Grippa Clutch'. I pulled off my side cover just yesterday to attempt a clutch adjustment. I went on-line and found the same video on clutch adjustment and watched it. The guy had a special puller to pull the hub off the tapered shaft. Figuring I too had a tapered shaft, i buttoned it back up and planned to find a puller.
However, looking at the picture of the 'grippa clutch' that was also attached, it is apparent that clutch had a splined hole, and no means to attach a puller. Normally, a splined shaft is not tapered, and if it is not tapered, I wonder if a puller is even needed. I'm thinking this one might just slide off the shaft.
Once off, I will begin the guess work of how tall to make the washer stack. As it is, my bike has so much clutch slip, even at very high RPM, as to be almost un-ridable. That on a brand new S6S motor...
Rich
I've had good luck with the two shoe with red springs,0nly after 30 hours or so the springs loose there tention and need to be changed.Yes I have had three shoes brake only one on my bike and some shoes never brake.The looser the springs get the more power or stall you loose climbing small hills and accelerating. Now the three shoe is a sweet clutch if adjusted properly which is real easy, you can drop the RPMs by 7to 800 by just removing the .005 shim.You should have Two .oo5 and one .010 which should set the stall at the desired RPM.( remember these engines come from the land of Ferrari and Ducatti)
When changing the shims in the 3 shoe I plug the breather hole and lay the bike on its side then remove the clutch it's alot quicker this way and you don't have to drain the oil every time you make a adjustment.Hope I was some help.DM
Thanks Dean what washer stack configuration are you using? /)(( . What oil are you using as well?
I use the stock configuration // ( ) ( ) ( ) ( )with Castrol 4t 10/40 and I change the oil about every8-10 hours and it does come out filthy!
For those of use that have mixed our washers up already...
Goat Herder; / / ( ) ( ) ( ) ( ) hope it works this time!
