Started this project the begining of August.
Its nice to be on 2 wheels again.
I pedaled Mt.bikes like mad from 1987-1997, some times 90 miles or more, now it just hurts.
I have had dirt bikes since i was 10, now i'm 43,150lbs and out of shape.
I wanted to do this build for around $1000...LOL!
After coming to the conclusion that all the parts on the 'new' project bike are junk, i replaced everything but the seat, kick stand and fenders...good grief.
Cha Ching!
I should say that the bike parts are fine for riding a couple blocks to the beach or where-ever at 10mph or less.
I felt that +20mph for 20 miles I want some decent parts on my bike.
Fito GT (single speed)(Felt knock off/look)
Magic pie 3 (rear)
CODD power 48v 10a lifepo4 (in frame mount)
64 lbs. built
17-20mph flat no pedal (will go 25+ in all actuality) Had the wheel size set too large for about 4 months...doh.
32mph max...so far (on gravel road/down hill) Whoo Hoo!
48t front 16t rear gears, can pedal to about 25mph then run out of gears
I had more of a 'dirtbike' like feel in mind, maybe a little "Oh Sh*t!" factor...not so. Its more like i have the legs of a 20 year old again.
Not sure 'torque and magic pie' should be used in the same sentence. (wrong, user error)
Have to pedal up hill or it will slow to a stop.
In grass, just gass'n the throtle it wont move without pedaling.
Torque arm seems a bit overkill now, not to sure i will add one.
---(edit* User error, 10a/20a max,software setting,whoops)---
Flat tires REALLY suck, about 60 miles the first week on bike so far and a flat rear left me walk/lifting 3/4 miles, got lucky was on the way home. Motorcycle tires are solid enough to support the weight of a bike, not so with bicycle tires, your on the rim, BAM!
Slimed the tubes...cross fingers that stuff works. <--EDIT, Slime is terrible, wrecked 2 air gauges from the junk getting into and gumming them up, I wont use it again.
Need to put a tool kit together to keep murphy at bay.
Only had one issue with the MP3, i set the regen brake to 0%(software) and it killed the throtle, seems as if you have to set it to at least 1% or no go.
That had me stumped for a bit as i had changed the setting when i fixed the flat, i thought maybe i damaged the wires or something. Glad that was an easy fix.
Great web site thanks for the inspiration.
Fun stuff!
Cha Ching!
Magic pie 3 (rear)
64 lbs. built
Fun stuff!
