Centrifugal clutch Kit Questions
Bob Mac 18704
129
3
18
penna.
It will work with the shift kit but you won't be able to bump start it. You will also have to install the pull starter. Also, their is a difference in the motors. The ggg motor is the motor that comes with the cc. The ones that come with the hand clutch have a different crankshaft. The hand clutch crank has a tapered end where the clutch mounts. The ggg motor does not. The cc will mount to the hand clutch crank but be careful not to tighten the cc bolt too tight as it will crack the bushing and render the cc useless( ask me how I know). My motor works and has many miles on it but for how long, I don't know. If you want to do it right, buy the ggg motor and start from there. It comes with the pull start already on it. This is only my opinion, others mileage may very.
