I took off the shock, unscrewed the spring preload adjuster, removed the spring, cut an old piece of bicycle frame tube the same length as the spring and installed it where the shock used to be. Now its a solid attachment w/ no rear suspension.
Heres a pic.
Ill test ride it tomorrow both pedal only mode & with the engine assist to see if I'm happier with it as a hardtail.
-Lowracer-
Heres a pic.
-Lowracer-
