This is bike 2, after realizing bike one is akin to a buckboard (even with the suspended front end, sus. seat post and cruiser seat) at my typical 20 mph cruise speed, I decided full suspension and some more hp would be nice.
The Huffy frame is stretched a bit with a full suspension triangle grafted in. Wheelbase 53". Using Puch wheels and front end.
Black HF 6.5 engine.
Idler clutch with HT lever & belt drive to a bike rear hub (acting as a jackshaft) to chain to the back wheel.
Initally I wanted to use a derailer on the drive side but that did not work out at the time. The chain needs a lot of tension on it to stay on. It may yet work by limiting the selection to 2 gear speeds. My tensioner is a lot stronger now.
Anyway, I have been running single speed and the engine has so much torque (12 ft. pounds and 9+ hp with the free breathing intake / exhaust and re-jetting).
That take off is no problem, slipping the clutch a bit. Gearing is 7.5 to one.
top speed on the tweaked governor is 35mph.
I posted how this engine is a vibrator. I actually bought a go-kart clone engine to replace it and the clone vibed just as bad. I went with isolators below the engine and rubber snubbers on top to hold the engine and this totally solved the buzzing. Still shakes at idle like before, but gets silky smooth at rpm. It's like a different engine.
I don't know how the bike chain will hold up over time. I pounded on the 10 speed chain that I began with for acceleration and speed tests, no problem, but, it came off and wrapped up a few times during the derailer testing.
That chain came apart going uphill on the way home Sunday.
Switched to a cruiser chain that was unmolested.
I would love a full belt drive but will wait to see how the better chain hangs in there. The belt slipps a bit on WOT but is no problem.
This thing rides like a dream! It is heavy @ 130# , seems like a small motorcycle. Very stable. Brakes could be better, using a dual brake lever, the moped brakes disappoint me a little. Bike one with calipers stops a lot stronger.
Very quiet, with the long exhaust system and a drilled- out Puch muffler, it has a subdued cycle sound.
I am pedaled- out at 10 mph, so I don't get much exercise on bike 2, but I sure like the power and the ride. Fuel milage seems great. The engine is loafing almost all the time.
I succomed to practicality by putting a basket on the back rack.
The center pic is a sample isolator. These things are the cat's meow.
