Almost forgot to do this post.
Here are some pics of my set-up. I kept the shopping bags from the gas/ electric set up because I like to ride this like a bike and prefer the engine to be not seen.
The drive side of the engine is a little cluttered, but you can make out the arrangement.
Oh, the stop light switch is from an appliance, I placed it on the rear brake caliper.
In the second pic, the copper looking thingy is a belt guide of sorts- when the "clutch" is pulled in, the guide keeps the belt near the pulley so it doesn't drag on the engine. Another guide is on the top side.
I am using a HT clutch lever that pulls back the engaging spring loaded idler (clutch). Works real nice- super light clutch action and bites good.
Brakes are a dual pull lever acting on a "V" up front and caliper in back (gorilla grip but stops good). Always avoid caliper brakes if you can- they are pitiful. I extended the arms to get more pressure to the pads.
The 250 watt "generator" is held in place by a band clamp to a home built pivot/mount. Gives adjustment sidewise and holds good. A spring pulls the belt somewhat tight. Had to grind a little off the motor shaft diameter to fit the pulley (pulley from McMaster-carr- love that place).
