coil blowouts
freebill
10
Dayton tx. USA
what i would like to know is, if i have my lights and horn grounded using the bike frame could this be causing the coils to go out ,,,like when im turning from the roadway i signal and break light , could this send some kind of juice in to the coil? thanks for any replys
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Unless you're trying to power the lights from the engine magneto, no, simply using the frame as base ground will in no way compromise the ignition system.
freebill
10
Dayton tx. USA
ok, thanks 2door, i was'nt sure i thought the spark had only one place to land, in the jug, so i get a couple of coils next week and try again, lol
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
You haven't said what engine you are having ignition problems with. If you are seeing magneto or ignition module failures there might be a problem we can help you with. Is this a Chinese 2 stroke we're dealing with?
