How interested would people be in a hard number, objectified comparison between the stock CDI and the Jaguar CDI? I see people constantly knocking it, claiming any gain is a placebo effect, and some people praise it. I'll try to get as much data as I can, my jag has 4 jumpers for a total of 9 settings, I just recently got ahold of some jumpers that I hope fit. If there's interest in this by tomorrow after work (around 17 hours from the time of this post), I'll do some testing. Only objectified numbers will be posted (and if people want, subjective vibration ratings) Please post any additional things I should try to look for when comparing before I go about the tests. I hate misinformation so I want this to be the end-all argument about the CDI. Of course your motors will differ from mine (as all HT's will) but being run on the same bike, through the same tests, should provide a good enough baseline as to which is better, and who's right. I will update this first post and bump when the results are posted.
If you want "spark strength" I do have access to a digital volt meter, but I have no idea where to test (or even what setting to use... I've never used one). In theory I could do the last 4 tests all at once.
So Stock CDI vs Jaguar CDI (all 9 settings)
tests:
Hill climb time and speed (20kph run at it (to remove human clutch feathering bias), base to crest, 1/4 mile)
Top Speed (taken over 5 blocks ~1/2 mile, both ways averaged)
Heat (WOT run, taken immediately after top speed test)
0-60kph time (No pedaling)
Vibrations (I might be able to find something for my phone, but it may not pick up the bike vibes)
tests:
