Let me start off by saying since I got this motor it was a ***** to get going. Once I did it ran great, eventually noticed the exhaust wasn't too tight and a gasket was completely missing the bottom half thus the exhaust residue on the block.
Now I made my own gaskets and what not, rode it yesterday chain kept throwing so I didn't go far, but enough to let the plug show it's nice color, and get the engine warm. She likes to die occasionally when warm, not sure if it's due to the lines vibrating though I loosened them a little more.
Also yesterday the exhaust came loose, which also caused a difficult start situation. I've checked the exhaust earlier wasn't loose but I'll see once it's cold.
So today with chain not flinging off, I rode a few miles letting the engine idle and turn it off every 20min or so. Started great, ran pretty good. I played with the A/F screw, during idle turning it 3 or so turns clickwise while ilding and i could hear it bogging and die. Turned it a turn back, rode. would bog under more then half throttle. Now I've turned it counter clockwise all the way till it was nearly going to come out, and it still doesn't run right. This is after playing with plug gap, though I've put it back to where it was before roughly. It's prob about .20, I tried to get it around .25~ manually but when I got it spaced and went to start, was a pain and wouldn't run. Closed the gap alil more and it ran, bad.
Engines a Keyang KY 171 32.9CC
Running Echo 50:1 semi blend premix, 50:1 is for 1 gallon, I put the entire bottle pretty much except the last drops in about .4 or .6gal, I forget. So it's either 25~32:1 roughly. The engine doesn't smoke much.
Also I noticed when it doesn't want to run, jiggling the choke up and down and it spikes back up with the throttle, try to leave choke up too long and it dies. If you do that for a bit and then keep the idle up, and eventually put choke up and go, it'll idle but occasionally dies.
Sorry if thats confusing as ****, I tried to point out the details of how this engine was running and what does what. If it was let me know what needs more explanation.
Also I got it with a ghetto gas tank, bike water bottle. Bottle was like 3/4ths full and 2 miles roughly ate it till empty, maybe it's too rich?
Edit: After chatting I feel the plug may be damaged, but the carb is alil wet, not much though. Also the motor has ran like a rabid ape choke not on, high load. It wasn't till i dicked with it that it messed up. I have seen lil black things in the fuel lines occasionally though, so maybe I need to rebuild the carb and revise my fuel setup.
http://www.ereplacementparts.com/walbro-wyk991-carburetor-parts-c-139716_142763_142479.html
Any idea of other names of the above, maybe a local store might have it. Otherwise I'll have to wait to order online
