Here's my project, I found the "Jeep" mountain bike, the back wheel came from a Honda moped.
The back wheel has a internal 12:1 reduction gearing with a disconnect lever and includes a drum brake.
The clutch housing is a Stanton unit machined with two sets of mounting holes for a Honda GX31 or a Chinese pocket bike motor, I also made the mounting system so I can fit other types of engines.The mounting system also allows me to shift to a different driven sprocket by sliding the motor mount sideways and up and down via the crescent shaped slot(spacer behind crescent slot makes up for the sideways movement)
Went for a test ride, but wasn't impressed with the power from the GX31, I haven't tried the 2cycle engine yet.
The drive chain is a #35, but chain noise is a problem as it's going at engine speed, I'll try a cogged belt drive as soon as I can find some pulleys and a belt. Maybe I get the belt and pulleys from a overhead cam engine core although I'm limited to 2:1 ratio.
The stock front derailler twist grip is changed to throttle twist grip by removing a internal flat spring.
I have to get a 1/2 by 1/8 chain to match front crank sprocket to the rear freewheel.
I'm keep on experimenting and see if I can get it to run quietly so I won't attract any unwanted heat.
