I have built a ton of motorized bicycles and I am finally moving on to motorizing a small boat. I salvaged an old 10 HP Lower Unit and welded a 44 tooth sprocket to the flywheel, which is horizontal to the ground. Therefore, I am going to have to mount the motor on its side. Obviously, I would need the carburetor to be mounted normally, but that is easy.
Will running an 80 cc 2-stroke on its side (i.e. magneto cover is lying flat, horizontal to the ground) cause damage to the engine or gearcase? Thanks!
