does anyone know where i can get a set of wheels for a metric sized trike conversion kit ?
the drive side is 16mm with a flat and the roll side is 14mm round, bolth have threaded holes in the end. i dont think the hollow hub wheels that i keep coming up with when i search will fit , they seem to be the same size and have a hole pattern drilled in the hub for mounting on a flange.
i am at a loss here as to where to get wheels for this kit and i may have to resort to gutting out a standard tire and pressing them on the axle with custom turned aluminum bushings, i am trying to minimize the work here.
i also dont want to have to swap out the axle for a 5/8 one ether and have to change bearings and drill out all the bushings !
