I sent them an email to find out what the ETA of the next shipment.Their site says "This product is currently not available. "?!?
I guess these are the new hot item!! -Justin
Looks like it wouldn't be a problem. I'll need to try it when I get mine.I wonder how this would go with the NGK extended tip spark plug that the shifter kit people are selling ?
LOL Bob. It never ends, eh?Great, just when I thought I was done modifying my 80cc....
I would order two cyl base gaskets: Zoombicycles Motor Bicycle Gas Engine Kits 80cc Cylinder Bottom End Gasket (A-7) | 10-Gaskets | 6-Parts and Accessories | RuiHong Enterprises Ltd., and one on their head gaskets: Zoombicycles Motor Bicycle Gas Engine Kits 80cc Head Gasket (A-3) | 10-Gaskets | 6-Parts and Accessories | RuiHong Enterprises Ltd.. I personnally have not used gaskets from them but i have only ever seen two versions of the base gasket and the only difference was the color and bolt hole diameters (same thickness). The head gaskets do come in different thicknesses, I bought my current head gasket from usabikemotors.com. I bought an engine from zoombicycles about a week ago and it had the same thickness head gasket as the usabikemotors one, therefore i believe all of the gaskets can be bought from zoombicycles in addition to the slant cylinder head. -JustinGreat, just when I thought I was done modifying my 80cc....
Anyone recommend a better/appropriate gasket for use with this?
Let me know how it goes and i will update the original post
Brendan is out racing...As soon as he gets back I'll ask him about this. If it's beneficial I'll definitely incorporate it into the new engines.Europorsche914,
Can you post pics of the slant head with the spark plug installed? I think the spark is also more exposed to the fuel air mixture, making the spark a little bit more advanced than conventional heads. I think this also makes it more efficient and more consistent sparks inside the cylinder...
Maybe Jim of CE can make a better version of this angled spark plug head, and put it in his engines...
Thanks...
bicycle-engines.com only sells 49cc's and the only grubee with slant heads are the genII & genIIA which are 49cc's & 58cc's respectively. they only place i have seen them for the 67cc/80cc motors is zoombicycles hopefully more suppliers will have them soon. -Justinjust so you guys know. zoombicycles isnt the only dealer that sells these slant heads,
like
Cylinder Head (Part #2) - $9.99
u might want to ask them if its actually a slant head cause it dosent say but the pic is a slant head
and heres another site. they have 2 for the different grubee styles.
1-2B Gen II Angle Fire Head - $14.00 : USABikeMotors.com, Star-Fire Motors and Parts
im sure theres other sites out there.
I believe the 49cc has a different bore diameter so it may not work...can the 49cc head be used on the 80/68cc motor if the holes for the head bolts are enlarged?
