Just got my Bikee E2 fixed up with the 48 volt, 2 speed Xiongda front hub motor. Want to show it off.
It uses roller clutches and reverses into it's planetary gear box at ~7 m/h, automatically, with my 16" front wheel, to go from low to high. High/low ratio ~1.82. I can hold it in low if I want. With my 720 w*h, 48 volt lithium pack, (right pannier bag) I can go ~20 miles solo, ~14-15 miles with my wife on back. It will climb a ~14% grade with 2 aboard, no pedaling. No speed demon. For tourist town cruising. Best efficiency at ~14 m/h, and huffs out at ~17 m/h. You will see us riding around Pismo Beach from Jan-March, while winterbirding.
In a former life, this bike had a 35cc Honda, thru a Staton 18.75 box with a 13 toothed sprocket, chained to a 27 tooth sprocket, attached to the big Nuvinci hub, with developer's kit, laced onto my 20" rear wheel. I built a 12v charging system for it, which enabled me to be the only NVDK user that I know of to get this kit to successfully shift up and down under power. Winched like a champ, but it was too loud for the missus on back. Our Xiongda hub is totally inaudible to her now.
If it warms up, I'll try for a vid....
