I'm trying to adjust my mixture since I put on a new pipe and filter. I moved the clip up 1 notch to lean it out because it was really bogged out before. Now it's running a little better, but still 4 stroking at 1/2 and 3/4 throttle, but fine WOT. Does this mean I can lean it out another notch? The color is a light tan color, which I thought was normal and how it should be, so why is it still 4 stroking? I should also add that this plug has about 20 miles on it, so it is very new, will this make a difference? Will it 4 stroke at all if the mixture is perfect or should it not 4 stroke at all if I have it dialed in correctly? Look at the picture and let me know what you think. Thanks.
