I'm working on a bike bug engine
I am putting an electronic ignition module on the engine and though I got spark once, I haven't got it since.
I have no clue what a Bug Bike is, but if it has a little (48cc-66cc) 2-stroke it has a CDI (Capacitor Discharge Ignition) module.
It has a black and blue wire in and the spark pug wire out.
I spliced the wire to the coil with the wire to the kill switch and to the positive side of the module. The negitive side goes to ground. What do I do with the lead wire?
Thanks
You put the kill button in series with the blue spark wire?
You know that kill button is a normally open switch you use to short the ignition to kill the engine right?
That means if it is in series you have to keep the button pressed in for it to run and the engine dies when you let go.
Most older magneto's have a black, blue and white wire.
Black is ground, blue is spark, cut the white wire off.
Just put the kill button across the black and wires.
