Sprocket Mounting Holes....The more the merrier?
Andyinchville1
Manufacturer/Dealer
Dec 26, 2007
502
Scottsville, VA
HI Guys,
Just trying to get a little feedback on how we can improve our Super Sprockets....
Our current "regular" Super Sprockets have 4 mounting patterns on them...
1) The Large Bolt Circle 8 MM 9 hole mount. (HD Factory Rag mount)
2) The Small bolt Circle 6 MM 9 hole mount.
3) The Large Bolt Circle 6 MM 9 hole mount (basically reuse holes from #1 above BUT use 6 MM bolts instead of 8 MM bolts).
4) The direct to disc brake hub 6 bolts holes.
I am wondering how often (if ever on the "newer" engine kits) is #2 used?
If #2 above is no longer regularly used, I was thinking about removing those mounting holes from our "regular" Super Sprockets adding the (2) Manic Mechanic Mounting patterns and maybe even throwing in a pattern or two from the Grubee HD hubs as well....
I think the Manic mounting patterns will work on our current sprockets as they are now but some of the holes will be very close together....Not necessarily a problem from the structural standpoint but more from an aesthetics standpoint (people tend to get a little uneasy if there isn't a lot of "meat" around bolt holes).
Thanks in advance for your input.
Andrew
(The reason I bring this up is because I had gotten a few calls over the past several months where a person was "on the fence" about buying a sprocket because they were undecided as to how they would ultimately mount sprocket to their bike...I figured the solution would be to have all the more common mounting holes on 1 sprocket).
A a side benefit, since most of our work has been with the Top Hat Sprocket / Disc Hub side of things, it probably wouldn't hurt to expand sprocket production to cover the sprockets needed for "clamshell" type adapters as well.
Venice Motor Bikes
Mar 20, 2008
7,272
1,810
Los Angeles, CA.
The smaller 9-hole pattern (#2) is what all my 4-stroke kits now come with... (so there are plenty out there).
Another hole pattern you might consider adding is the Sportsman hub adapter pattern; Many people are using them these days & being able to use your colored sprockets might be a nice option?
