three weeks worth playing summary
1st run carb wrong, ran wide open- fixed installed barrel correctly
2nd run going to work pedaled over half way 6 miles total- ran and quit adjusted screw on carb top ran better still quit but restarted after short burst of pedals got home adjusted carb more
3rd ride to work ran good took long way home got home and hooked up kill switch ground to frame other to BLUE from engine
4th ride to work clutch cable pulled through no clutch by time got to work by that I mean clutch was engaged and would not pull off
installed new cable after work and made one lap around parking lot before engine faded and now wont start fire ... pedaled all 6 miles home holding in clutch!
now
I have spark at least some! (replaced stock wire and boot 8mm from autozone) added screw thing to sparkplug
I have fuel I have cleaned out the carb bowl found particles and flushed more gas through with bowl off installed clear filter in line
I get nothing with different adjustments
HELP!
now
HELP!
