Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make your motorized bicycle run smooth and trouble free
4g tapered shaft clutch/trans issues
Old 12-17-2013, 12:10 PM
david631 david631 is offline
Default 4g tapered shaft clutch/trans issues
I have an Electra bike with a 4 G tapered shaft motor. the problem I am having is with the aluminum case and steel clutch. the hole that the two bearings and drum with shaft are pressed into has elongated due to the bearings freezing up and spinning in the housing. has anyone out there experienced this problem or know a way of repairing it. I'm also not against buying a god one if someone out there has one. also need steel clutch shell w/welded shaft.
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
MotorBicycling.com
