Hello all,
while the main restoration job on my 1956er Thoria light motorcycle is makin good headway, i am kinda stuck with the rear brakes today. Hope that somebody has a similar bike and can help me out of my pit. Thing is : When i bought it, the rear brakes were connected to the brake-foot pedal with a throttle cable (bowden cable) which ended in some small adapter shell. It was totally rotten, so i didnt mind too much as i thought i can replace it with some self tailored solution. Meanwhile i was thinking if i can maybe replace the wire for a thin brake-steel rod, and i think i want to go for that as i do not see any advantage for the cable solution over the rod (anybody opposite ideas to that?) but my main problem is the question how thatv rod / wire is to be fixed on the rear brake lever. As you can see in my attachment, i can identify the notch/hack which is to hold the shell with the adjustor-thread/worm. But it is completely loose, its just laying in there and its not fixed at all, so i would guess it will take the first opportunity while i am pulling the brake and hop right out of that hack - wouldnt it ? I have seen similar levers on my other old bikes, but they were slightly different, on these other bikes the arm/lever didnt have an open hack, but a fork which has a hole on both sides, a shell is pushed through which then holds the addjusting thread of the steel rod. In that szenario, nothing can move out of the brakes setup, but here ?? Does anybody know how this is supposed to work, can send a picture or a firm description of what i may be missing here ? Thanks in advance, excuse my bad english, hope i could make myself understood...
Cheers,
Lars
Cheers,
Lars
