yes you will need a rectifier , theres a great how to on here I believe its diy rectifier, i'm using it an it works well , then you only install 1 zener in the positive power lead be sure you install it in the correct direction that diode has a line that marks current flow make sure that line is towards the lights side of the wire . easy as pie .
Gary
Gary
