Actually you can go without a cylinder to case gasket completely. Use a gasoline resistant/compatible sealant and make sure there is a good layer on the contacting surfaces. Torque the head down properly, 120 to 140 inch pounds and check the torque after a couple of heat/cool cycles. The cylinder head to cylinder is a different story. There you need a gasket and a flat surface to get a good seal. Soft aluminum or copper will suffice. Sealers are not required for a head gasket properly installed.
