this may not be the only way or the best way to stretch a frame, but i feel confident in the strength of the end result. Far more confident than simple butt splices
i create insert slugs using tubing with a similar diameter to my work, these are a snug fit inside the work and protrude past the ends of the finished tube ends
this provides structural support, doubles the wall thickness, and provides a heat sink when doing the exterior butt weld allowing better penetration
first i slit the tubing, twice to remove a strip approximately 1/2 inch wide
then i use a rubber mallet to convice the tubing of it's new diameter, gentle - keep it round(ish) and slip it inside the sleeve and ultimately the recieving ends
i drill some holes in the recieving tube, to be welded in, holding the slug in place
then i go back and do the but welds on the exposed work piece
