commercial 4 strokes just last alot longer. found this on google and learned some more specifics about the briggs i didn't know
The vangaurd is they’re commercial line, top grade.
The powerbuilt is at the bottom of the scale….. not the I/C
the powerbuilt is all aluminum and plain bearings. No oil filter splash lubed.(oil dipper on crank)
The I/C (industrial commercial) has bronze bearings and a cast iron bore. no oil filter, splash lube
The intek has larger bronze teflon coated steel backed bearings, with a cast iron bore, may or may not have a oil filter depending on hp range. Premium ring package, and pressure lubrication.
The ELS (extended life series) Has chrome plated valves, teflon coated piston and cast iron bore. Its basically the intek…… just better longer life valves and full flow oil pressure. And oil filter.
The intek and ELS come with AVS on them (anti vibration system) the I/C may or may not.
