Ouch! HS 49cc with broken exhaust valve
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
24
Ridin' inSane Diego, CA.
I recently bought two 49cc Honda clone engines used......one was fine, the other had a broken exhaust valve. Luckily for me, the only damage is the exhaust valve itself and a slightly bent ex. push rod. Other than that this engine is in extremely fine shape, here's some pics......
dnut
scotto-
Jun 3, 2010
6,505
24
It looks like the valve came off the keeper somehow......it would have snapped where it did after dropping into the combustion chamber. Yeah, very lucky the damage was minimal......and yes these parts are cheap!
dnut
scotto-
Jun 3, 2010
6,505
24
Whoah! Wonder how that happened? At least there's no serious damage, good thing parts for the HS are so cheap! :D
OK, here's what happened after inspecting the failure. It looks to be a wornout exhaust valve keeper was the culprit. The valve dropped into the cylinder (cumbustion chamber) and nearly reeked havoc on the engine. I ordered a new exhaust valve (and an intake valve as well for good measure), did a little port work and put it all back together.
Went to start it up and no go. Put a little ether (starting fluid) to it and it started right up. Then I put the propane to it and the same thing.....it ran fine. So what does this tell you? It tells you your carburetor is not doing it's job. I pulled the float bowl off, pulled the main jet and emulsion tube and low and behold, found the problem.
The problem; a clogged main jet. Clogged solid with some yellow powdery sunstance. The solution; had to re-drill the main jet. The result; engine runs like a champ now!
It sure is rewarding to know how to do this stuff and it saves a heck of alot of money as the end result. Let's ride!
dnut
scotto-
Jun 3, 2010
6,505
24
That valve keeper was probably cast by the same guy who peed in the "sugar" bowl that the carb jet was dropped in lol
Yeah, prolly rotfl Those keepers are really hardened, makes me wonder why it wore out so quickly. The guy I bought it from didn't even know it dropped a valve......he say's "it doesn't turn over when you pull the starter" as he's pulling on the starter laff Can't believe nothing else was damaged in the event.....still would have been a cheap fix.
Here is a short vid of it running today......nice gearbox huh? laff
http://youtu.be/9l7FRE8n_ZE
dnut
GearNut
5,104
11
San Diego, Kaliforgnia
Looking good. Sounding good too!
So, is it a Hoot single row chain or the better duplex chain box?
Why do I imagine you stuffing this into a modded 20" BMX frame?
scotto-
Jun 3, 2010
6,505
24
Thanks Dan, it's a single row box. You only imagine stuff like that cuz I can.....and I will :D
You up for a ride soon? You know how to reach me.dnut
