I am in the process if replacing ALL GASKETS, and SEALS in my ht engine because of some wierd problems. However, I ran into 2 problems while taking it apart. First off: How do I remove the clutch drive gear nut? What tool should I use because it is very wide for a screw driver. Also: How do I reinstall the piston back into the cylinder? Is there something special I have to do to piston rings to get them to go back inside the cylinder? because one side pokes out and the other side goes in. The piston rings are in good condition nothing wrong with it.
