30 Miles and WT#!!!!
Sign Guy
87
Everett, WA
I was in a **** of a jam like this a few months ago. Fuel was dripping out of my exhaust when i cranked it over and over, I had spark outside the motor and everything was sealed up with silicone and rtv. Turned out that my spark was very weak, and was blowing out under compression in the motor. I borrowed my friend's cdi and then she started with ease. Just something to ponder...
Was it really hard to start? Like you had to ride and ride and ride to get it going? Mine started in 30' and now it's 3/4 of a mile before it starts to kick to life. I think my cdi is bad. hmmm...
rwquiring
120
Bend, Oregon
when I got it going it would start in about 6 feet, then all this started to happen.
Q
rwquiring
120
Bend, Oregon
completly took carb apart this afternoon still no effect, could this be a mag or cdi problem? how does one check them, remember now, I am a cabinetmaker not an electrician so explain it for a dummy...
Q
Venice Motor Bikes
Mar 20, 2008
7,272
1,810
Los Angeles, CA.
Cut off the plug in connectors for the CDI & solder & heat shrink all the wires together, then replace the spark plug, wire & boot with quality parts.
See if that does the trick.
One more thing... disconnect the kill button!!!
rwquiring
120
Bend, Oregon
but if the cdi is shot, am I just throwing away more money rather than just buying a new one?
If I disconnect the kill botton how do you stop the engine?
Q
Venice Motor Bikes
Mar 20, 2008
7,272
1,810
Los Angeles, CA.
Q
The spark plug, boot & wire are all parts you should replace anyway.
You can stop the engine by slowly letting out the clutch until the engine dies or by flipping the choke lever up. (The kill buttons are notorious for shorting out the CDIs & mags!) :(
*edit* You should always solder those CDI wires! (the plug ins are sh**)
rwquiring
120
Bend, Oregon
is there any way to tell if the CDI has been shorted out?
Q
GoFastBicycles
557
West Point PA.
I read you say you have spark so I say your CDI is good. remove the kill switch wires and try.
Norm is right about upgrading your boot and wire.
Adam
Also look at the mag check for loose connections.
rwquiring
120
Bend, Oregon
Adam
Sometimes I have spark so maybe it is in the wire and boot, Have looked at the mag and every thing looks normal to me (rookie you know so what do I know?)No loose wires or solder joints..
Thanks
Q
GoFastBicycles
557
West Point PA.
When you took the carb apart was the brass tub attached to the base of the carb? It is the tube that slides in the middle of the fuel float. It happened to me and after replacing every thing on the bike but the carb (yes i mean every thing engine too) I still could not get it to fire. So that left 1 thing the carb. I took it apart and the main jet tube was not attached to the base of the carb.
Adam
rwquiring
120
Bend, Oregon
Adam
Yes It was attached, I did find a LOT of debris in the fuel filter, changed the line and the filter. Got parts for new plug wire and boot and a new NGK bp5hs, Have to help my son move this am so I can't work on it now but will this afternoon. I will keep ya'll informed...
Q
GoFastBicycles
557
West Point PA.
Q
If by chance yo put the small filter on the petcock remove it.
Adam
