Is this worth trying for?? Will be my second build.
wheelbender6
4,059
221
TX
The AMF has 26 x 1/8 tires. I used that size wheel successfully on my motor bike for a while. The drawback to that wheel is that you can only run 26 x 1 3/8 sized tires. The common mountain bike tires like 26x2, 26x1.75 and 26x2.3 have a smaller bead diameter and will not fit those 26x1 3/8 rims. I found that out the hard way. Broke a lot of tire levers in the process.
curtisfox
6,048
3,959
minesota
If you do some digging you can find 3speeds with wider rims. I am doing the same thingand thats what I have. Or they made wide 10 speed rims also............Curt
Tacomancini
163
Pittsburgh
I swapped the 26x1 3/8 S8 wheels on my schwinn to standard 26’s. it worked out okay, but the pedals are now closer to the ground, gotta watch that on turns. Also, the wheels on my bike were that super rare schwinn size. On that bike you may have the EA3 tire size which has many more options tire wise. In fact the resurgence of the 3 speed in popularity seems to be bringing more tire options. Like check the beautiful white shwalbe tires on Sheldon's site: 26 x 1 3/8 inch (590 mm) Bicycle Tires from Harris Cyclery
Velodrome
2,387
271
Phoenix-ish
the amf has 26 x 1/8 tires. I used that size wheel successfully on my motor bike for a while. The drawback to that wheel is that you can only run 26 x 1 3/8 sized tires. The common mountain bike tires like 26x2, 26x1.75 and 26x2.3 have a smaller bead diameter and will not fit those 26x1 3/8 rims. I found that out the hard way. Broke a lot of tire levers in the process.
!!! Use the force luke !!!!
