runnermike Member Nov 18, 2012 936 0 16 Sanford, FL Feb 24, 2013 #1 Does anyone know what you should torque the mounting bolts to? Also, the intake and exhaust bolts? Thanks. I've tried searching, but can't find it anywhere.
Goat Herder Gutter Rider Apr 28, 2008 6,237 20 38 N.M. Feb 24, 2013 #2 8mm studs more more than 175 inch pounds 6mm studs no more than about 80 inch pounds. That should keep you out of trouble? https://www.boltdepot.com/fastener-information/Bolts/US-Recommended-Torque.aspx
Wickedest1 Member Oct 31, 2012 688 7 18 41 connecticut Feb 25, 2013 #5 On my 2011 flying horse I've torqued the mounting studs to 85 inch pounds...after hand tightening of course...have had no loosening issues and they are still at 85in lbs...good luck
