Centrifugal Clutch vs Normal clutch motor
dmpatanis
39
Greece
Hello,i bought from ebay bicycle motor kit with centrifugal clutch and a pull start.
Whitch the diferrent with normal motor????
I have got problem with my peddals,i need wider???
My bicycle is a mountain bike.
Thanks a lot.
Chalo
78
Texas
What to do if i need wider crank???
How i can make wider crank???
Regular bike shops can supply bottom brackets (the shaft and bearing your crank arms attach to) up to 127.5mm. Sick Bike Parts has bottom brackets in 131.5mm, 153mm, and 206mm.
I installed one of the 131.5 units on a customer's bike the other day, and I can attest that they are high quality parts and very fairly priced.
Chalo
KCvale
3,966
57
48
Phoenix,AZ
If you have a 3-piece crank you might be able to just get by with pedal arms that bend out. If is the 1-piece crank you will need to replace the whole assembly as mentioned above.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
N.M.
Three piece crank tend to be aluminum. I would not advise bending aluminum.
